TYGA does it again!!!
RGB500
Fri May 14, 2004 1:37 pm » Post: #1 » Download Post
My shift lever on my Tyga steps broke last week due to fatigue.
I contacted Paul and he sent out a new upgraded lever at no charge, and had it in 5 days. You can`t beat that for customer service. Thanks Paul.
TYGA ROCKS!!! Very Happy
Mike
Mike
rzv500r
Fri May 14, 2004 6:00 pm » Post: #2 » Download Post
What did the upgrade consist of?
Guest
Sat May 15, 2004 2:09 am » Post: #3 » Download Post
The new lever is machined out of solid one piece billet, where the other was a two piece unit. You definately notice a difference in the way the shift lever feels.....much more positive feel with less free play.
Mike
stepp
Guest
Tue May 25, 2004 7:31 am » Post: #4 » Download Post
I just got a whole box of goodies from Tyga, everything was perfect except for a small crack in the Tyga eyes uppers, but that was undoubtedly due to the package handlers which im trying to get some insurance money out of.
but anyway, anyone know how to patch up a small crack?
Tyga does ROCK!!!
Tue May 25, 2004 7:34 am » Post: #5 » Download Post
stepp wrote:but anyway, anyone know how to patch up a small crack?
Oh the temptation to take this thread into the gutter is enormous! Laughing
Depends what the mterial is - plastic or fibreglass...
stepp
Guest
Thu Jun 03, 2004 7:34 am » Post: #6 » Download Post
hahaha, i forgot i asked that question, the material is fibreglass, i guess i could have worded the question differently eh?!
nsrmonkey
Thu Jun 03, 2004 10:41 am » Post: #7 » Download Post
i know you can buy fibleglass repair kits that come with the fibre cloth stuff and all the chemical glues n stuff, i bodged a car wing back together with one a few years ago and it dried really hard Confused . recon you can buy them from pretty much any boyracer type shop Laughing
do tyga do plastic fairings as well as fibreglass Question
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
stepp
Guest
Thu Jun 03, 2004 3:05 pm » Post: #8 » Download Post
thanks for the tip, i think Tyga only has fiberglass as i saw no options when buying.
is plastic the preferred material?
nsrmonkey
Thu Jun 03, 2004 4:46 pm » Post: #9 » Download Post
Idea as i have never seen the quality of tyga panels this is by no means aimed towards them.....and also i have heard nothing but good stuff about their kits. Exclamation
i used to sell bodykits for cars when i was in my first job and i found that fibreglass would or should i say have a tendancy to crack and split anywhere where there was alot of vibration, also on occasion you would get air bubbles between the fible cloth and the outer gel coat which when it was heated up in the spray booth after spraying would expand and crack the panels.
this was all of about 14 years ago so i am sure fibreglass panels are far better now Wink but to answer your question i recon plastic panels would cost the earth to make let alone buy, so if ya want anything but standard fibre glass is the way to go Very Happy
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Nutter
Nutter
Sat Jun 12, 2004 3:18 pm » Post: #10 » Download Post
The trick with fibre glass is too work clean and imagine that the resin is like gold so use as little as possible, acetone is the only think which will wash the stuff off brushes etc while still wet.
without looking at the crack i can only guess at the best way to fix it.. start off by taping the front of the fairing accross the crack to get it level and in the correct postion then work from the back.
1. cut medium weight chop strand matting to the correct size you are looking for about 4cm band over the crack. if you are working into a corner or a complex shape it is far easier to use tissue.
2. cut a paint brush down so its hairs are about half length a brush about 3/4" is normally most usefull.
3. mix the lapup resin with the hardener. the stuff from the car accesory shop is okay but expesive in large quantities.don't be tempted to use too much hardener as the resin will set with in a few minutes
4. paint the area with the resin and press the matting on to the surface then use the paint brush to stipple (press) extra resin into the surface.
one or two layers of matting should be aduquate.
5. when cured the repair can be cleaned up and any excessive matting can be cut off with an angle gridder. and finnished with wet and dry
the dust is nasty so wear a mask .
good luck
you can only get better with pracatice
