Problème d'ajustement des vannes RC.
Omegawatt
Sun Sep 17, 2023 7:31 am » Post: #1 » Download Post
Good morning,
Here is my question
When I adjust the valves with the center of the hole, the aligned mark,and the valve motor is on "hi" (method ON/OFF unplug the trottle) there remains 1mm of possible rise at the valve. ( for the 2 valves)
When I adjust the valves with the alignment of the exhaust port with my finger (there is a little play left) then I am 1.5mm to the left of the mark on the two valves.
Which solution is the right one? Did I do a bad thing?is the servomotor not completely opened with this procedure?
Sun Sep 17, 2023 1:10 pm » Post: #2 » Download Post
Setting the RC Valves with the "dowel" method is the quick & safe adjustment used at the factory during [mass-production] assembly. For most situations, it works absolutely fine.
Using the HRC method is, of course, the most accurate way to do it, but I wouldn't worry too much on a stock motor as the gain is often barely noticeable. Really it's for when you absolutely want to fine tune every component to the finest degree.
Omegawatt
Wed Sep 20, 2023 3:42 pm » Post: #3 » Download Post
Thanks Andy.
my nsr is equipped with a tyga air box with filter and tyga exhaust. I adjusted the carburetion and set the air jets to 100-75-50, I would like to correctly adjust my valves because there is still a significant difference. when I unplug the trottle and the valve motor turns to HI, is this the fully open position or intermediate adjustment position?
Omegawatt
Wed Sep 20, 2023 4:36 pm » Post: #4 » Download Post
ok I just checked. the OnOff position unplugging the trottle is an intermediate position. not HI full position.
at 2000rpm the HI full position is present.
Omegawatt
Thu Sep 21, 2023 10:15 am » Post: #5 » Download Post
https://youtube.com/shorts/l2Hs99Oxlbk?si=qB8x3gc2spFG9rU9
First test
Thu Sep 21, 2023 12:39 pm » Post: #6 » Download Post
Very nice! Although I can't condone those brake lines! 😁😁😁
Omegawatt
Thu Sep 21, 2023 9:03 pm » Post: #7 » Download Post
thanks Andy. for the brakes I have to agree with you
