Clutch leaver return spring
TheBlackadder
Tue Mar 12, 2024 11:01 pm » Post: #1 » Download Post
Rebuilding my MC16 still and got an issue with my clutch spring (the one that is outside at the engine underside and where the clutch cable is being attached. It seems that the spring lost its tension, as when I engage the clutch leaver it does not spring back at all. The cable is oiled and properly attached. When I detach the cable I can operate the clutch arm and feel little spring action. Any suggestions ?
prelude2.2
Wed Mar 13, 2024 8:39 pm » Post: #2 » Download Post
that's odd, I've never heard of that losing tension before. Is it an original?
TheBlackadder
Thu Mar 14, 2024 8:01 am » Post: #3 » Download Post
hmm, i am not sure. the engine has not been started for years - 10+? so maybe the plates got stuck - will hopefully get it to run soon
prelude2.2
Thu Mar 14, 2024 3:45 pm » Post: #4 » Download Post
yeah sounds like its time to take the clutch apart and inspect everything. Let us know how it goes getting her started.
Thu Mar 14, 2024 10:43 pm » Post: #5 » Download Post
TheBlackadder wrote:hmm, i am not sure. the engine has not been started for years - 10+? so maybe the plates got stuck - will hopefully get it to run soon
What you describe above is exactly what happened to mine after being rebuilt with no use for 2 yrs
I warmed the engine up and then cable tied the clutch lever in
Left it in 2nd gear and on a paddock stand and over the next two weeks regularly rotated the back wheel by hand until one day it broke free - lazy fix I know but time was a easier and cheaper currency than pulling the engine apart
