Flywheels! Honda NSR250 mc 18. PGM-CDI; PGM II.
Iron_Angel
Fri Nov 01, 2024 3:06 am » Post: #1 » Download Post
Hello friends!
I need some information.
Is anybody know? How are marked the flywheels according to table below? I want to know the numbers and letters applied to the surface of flywheels. It is how I understand is four different type of flywheels for MC18.
I need to know this information to find the flywheel used whith PGM-II.
I'm thinking about conversation my MC16 to PGM II ignition.
And one more question. Can me someone explane? Why the string between KV3-702 and KV3-703 in the table below filled by information? Is it a misstake? Is it need to shift the data lower?
https://workshop.nsr-world.com/MC18/MC18/E7Frame.html
REF. IDPart number Description NSR 250 MC18-100 NSR 250 MC18-110 Engine No.
R2J R4J R5K R5K-2
6 31110-KV3-701 Flywheel    COMP.  (DENSO) 1 - - - -------- 1031865
31110-KV3-702 Flywheel    COMP.  (DENSO) 1 - - - 1031866 1052731
- 1 - - -------- 1052731
31110-KV3-703 Flywheel    COMP.  (DENSO) 1 1 - - 1052732
31110-KV3-771 Flywheel    COMP.  (DENSO) - - 1 1
Tue Nov 05, 2024 9:34 pm » Post: #2 » Download Post
You need part number 31100-KV3-771 for a PGM-II.
'88 R2J
31100-KV3-701 ... -------- 1031865 [up to engine number 1031865]
31100-KV3-702 ... Engine numbers 1031866 to 1052731
'88 R4J-SP
31100-KV3-702 ... All engine numbers up to 1052731
'88 R2j/R4J
31100-KV3-703 ... All engine numbers from 1052732 onwards
'89 R5K/R5K-II/R6K-SP
31100-KV3-771 ... All engine numbers
The final revision (Japanese only) Parts List for double-checking can be found here: https://manuals.nsr-world.com/view-87-89-parts.php
Iron_Angel
Wed Nov 06, 2024 3:00 am » Post: #3 » Download Post
Andy wrote:You need part number 31100-KV3-771 for a PGM-II.
Andy, thank you.
My problem is to understand now. What kind of marking the 31100-KV3-771 flywheel has on his surface. I am not find any flywheel that bear the marking of the part number.
I see only this information on the flywheels. And how I see markings are different on the different flywheels. How to anderstand which letters and figures corresponding to 31100-KV3-771?
Iron_Angel
Wed Nov 06, 2024 4:13 am » Post: #4 » Download Post
These flywheels have other markings.
Thu Nov 07, 2024 7:42 pm » Post: #5 » Download Post
Almost certain 037000-2460 LKZ06 is 1989.
037000-2641 is MC21.
1987 and 1988 flywheels are a noticeably larger diameter than 1989-1996.
