HRC Spec Link Plates for the Rear Suspension.
Hudtm60
Sun Jan 26, 2025 10:49 pm » Post: #1 » Download Post
I thought I would make this a separate thread to try and show the difference between stock and OEM. Literally years ago Andy suggested. "While it's all apart, I'd strongly recommend a set of HRC spec link plates for the rear suspension. This will lift the rear about 50mm and quicken the steering, and also increase the rising rate of the shock, which is always going to be a little under damped/spring for us [usually] heavier western riders"
So I got some, sadly not from Performance Engineering which is where I should've got them, but on e-bay I think...
Anyway....here's the differences...note you can flip the HRC plates so it changes the geometry. To be honest I'm not sure which way to go. #1 or #2. I don't want to do anything that will change the stance so much that components start interfering with each other.
It's clearly not an exact science because I'm free holding the camera but I think you get the idea. It looks like Position #2 throws the swingarm down the lowest thus raising the backend the highest.
Stock Plates
HRC Plates Position #1
HRC Plates Position #2
Mon Jan 27, 2025 4:35 pm » Post: #2 » Download Post
We always fit them as HRC intended:
Don't recall ever having any interference between components, so should be good to go.
-10 points for not getting ours though! 🤣🤣🤣
Edit: I'd be interested to know what the dimensions of yours are. They don't look right!
Hudtm60
Mon Jan 27, 2025 5:47 pm » Post: #3 » Download Post
Wow so this is helpful....the long edge is horiztonal....it's not even any of the ways I tried it! the
Mon Jan 27, 2025 5:56 pm » Post: #4 » Download Post
I was under the impression that MC18 OEM link plates had a hole in them and retro fitted ones didn’t
Got me wondering now as mine are solid like your original ones Chris and I thought mine “had” been retro fitted but now I’m not so sure
Anyone got the Eye to Eye measurements to enable a basic check
Mon Jan 27, 2025 8:06 pm » Post: #5 » Download Post
This may be more helpful than a 3D image.
Shortest between the swingarm and dog bone, longest between dog bone and shock.
Hudtm60
Mon Jan 27, 2025 8:09 pm » Post: #6 » Download Post
Thank you Andy. I very much appreciate the specific guidance.
Pics will follow once installed.
Mon Jan 27, 2025 8:11 pm » Post: #7 » Download Post
No worries. I have Solidworks open anyway, and it's a break from work! 🤣🤣🤣
Hudtm60
Tue Jan 28, 2025 2:56 am » Post: #8 » Download Post
And here it is in a dry fit....
this is the shock by the way....about £329 from https://www.wemoto.com/bike/honda/nsr/250/1988/121/rear-yss-z-series-monoshock it's always comforting these days to have a component listed as being compatible with your exact model!
Old one is 'not refurbishable'
Hudtm60
Tue Jan 28, 2025 3:26 am » Post: #9 » Download Post
Nick,
measurements more less from the centre of each eye..50mm and 70mm
Tue Jan 28, 2025 4:52 pm » Post: #10 » Download Post
My MC18 rear shock was rebuilt at GT performance. It looks like new.
Hudtm60
Tue Jan 28, 2025 5:31 pm » Post: #11 » Download Post
and I actually had an allegedly un-rebuildable YPVS shock refurbished in Canada...so trying to remind myself not to believe everything I read...
(unless it's here of course)
Tue Jan 28, 2025 10:28 pm » Post: #12 » Download Post
RobH wrote:My MC18 rear shock was rebuilt at GT performance. It looks like new.
And that has always pissed me off 🤣😂
….. when I asked, I was about three years to late as they’ve stopped offering this service
However I to purchased a YSS exactly the same as yours Chris and was pleasantly surprised by how good it was.
Wed Jan 29, 2025 10:46 am » Post: #13 » Download Post
I think Brook Suspension will do an R shock.
https://www.brooksuspension.co.uk/
This was an R2J we did... maybe even yours, Rob.
