Loctite small allenhead bolts?
Enessr
Sat Dec 27, 2025 9:38 pm » Post: #1 » Download Post
I'm in the slow process of rebuilding my mc21 engine..
Does anyone remember if the bolts securing the internal transmission oil pump
Require the use of loctite on their threads?
I'm certain that the dam things were loctited in because 1 snapped whilst being
Removed, slowly and using lots of heat, no chance.. took me two days to remove..
My other question regards the sealant used to seal both the engine
Cases together, I have a new tube of threebond yamabond grey 1215, bought specifically.
I'm getting conflicting advice as to which to use though, some say this flavour whilst others go
For the black 1215R version.
Either of 'em would be OK?
Cheers!
ericandchi
Sat Dec 27, 2025 11:49 pm » Post: #2 » Download Post
I have always put red locktite on the transmission oil pump bolts.
As for the cases, I have only used the black suzuki 1207B on my NSR both times i split the cases, never had an issue. The black 1207B has a faster setup time and higher temp range than 1215R which is the gray stuff. My friend has split cases on his Honda CBR 600 and 1000 several times. He uses Hondabond HT. I'd probably use that if I had to go buy a fresh tube.
