2 questions
aikawa
2 questions
Tue Apr 04, 2006 8:47 am » Post: #1 » Download Post
First question is, when im about to go off i hear something in the carb or soemthing like something is flapping. What can that be?
Another thing i wanted to ask was, i just changed my rear pads and they squeek like a mofo, whys that?
Thanks
93' MC21
rc46
Tue Apr 04, 2006 1:05 pm » Post: #2 » Download Post
Did your brake pads have anti Squeel? Its Like a metal plate a mm or so thick on the back of the pad. If not then you need to line the back of the pad with some copper greese not to much just a thin layer, They squeel becasue the back of the pad is rubbing on the pistons or caliper edge!
Tue Apr 04, 2006 4:37 pm » Post: #3 » Download Post
Something is flapping? Can you describe it better? Is it when you let the clutch out? When you rev the engine? When it's in gear? Does it happen in neutral?
aikawa
Wed Apr 05, 2006 12:15 pm » Post: #4 » Download Post
for the brake pads i dont think there was any thin layer.But i'll get some grease like you suggested
for the flapping sound it happens when i'm in first gear and slowly let the clutch out.
93' MC21
rc46
Wed Apr 05, 2006 8:46 pm » Post: #5 » Download Post
Make sure its the copper grease, you can get a small tube from a bike/motor store, dont use to much and keep it well away from the pad linning!, enough just to coat the back around the piston area!
aikawa
Thu Apr 06, 2006 3:45 am » Post: #6 » Download Post
Alright thanks for the help
93' MC21
horde
Thu Apr 06, 2006 3:16 pm » Post: #7 » Download Post
another product is "antisqueel" made by crc- comes in a tube, wurth also make an aerosole version that you applicate to the back of the pads.
You can also get a file and file the leading corners (not too much) off the pad material. Use copper grease sparingly to lightly coat the brake pins.
Make sure your rotor isn't overly worn as this can also be the reason for noise- if so replace with new....
hope this helps.
........."I love the smell of 2-stoke in the morning.......Smells like victory"............
MC21 Pentax SP...... TYGA'D
