Engine cut out!
aikawa
Engine cut out!
Mon Sep 18, 2006 11:11 am » Post: #1 » Download Post
Alright so i was going around 150km on an expressway in japan. Suddenly my engine cuts out my rear tire locks up, I'm swerving around the road trying to regain control, pulled in the clutch and savely stopped to a hault on the side of the expressway. What the hell is wrong with my NSR?
By the way i was pulling pretty hard on the bike throughout the trip on the expressway. My mechanic suggested i buy a new engine, but i aint got the cash or time for it right now.
Any suggestions as to whats wrong with my bike? Electrical seems to be working fine, it just wont start anymore...??
I'm clueless.. guess the NSR isnt a daily rider huh?
Need suggestions..
Thanks
93' MC21
Mon Sep 18, 2006 11:15 am » Post: #2 » Download Post
Sounds like it's seized.
Is it modified? Has it been set up correctly?
Run out of 2-stroke oil?
Using crap oil instead of the good fully-synthetic stuff?
They (2-strokes) only blow up if you (a) don't look after them, (b) don't set them up correctly, or (c) if they are a Suzuki! Laughing
Mon Sep 18, 2006 12:34 pm » Post: #3 » Download Post
BTW, it'll be a piece of cake to fix in Japan! Parts are cheap and readily available second-hand.
I would be shocked if you couldn't get a used barrel (providing it only a siezure) and rebuild it for any more than £100 (¥20,000).
aikawa
Mon Sep 18, 2006 1:52 pm » Post: #4 » Download Post
Thanks
yeah its basically stock except for mfactorywest silencers and the wiresplice(stock jetting). Been using Castol TTS oil. I think its because of the wiresplice (did it like a month ago)
So what should I be looking to fix? Oh by the way the bike has about 19,768 clicks. I called JHA about a rebuild and they said they charge around $3000-4000!! Theres no way i can pay for that and that seems like a rip off to me. Thats like worth more than the bike itself..
I need some suggestions..
Thanks guys
93' MC21
Mon Sep 18, 2006 3:59 pm » Post: #5 » Download Post
aikawa wrote:
I need some suggestions...
Yahoo.co.jp!
I already looked. A useable barrel on there for $80, and the rest of the bits for about $120.
aikawa
Mon Sep 18, 2006 4:03 pm » Post: #6 » Download Post
Thanks
Found the barrels, what else will i need?
Forgot to mention, after it seized, I tried to start it again, and it did but the top cyclinder wasnt firing and so it wouldnt idle.
Do i need to rebuild the top end or get some used barrels from yahoo??
93' MC21
Mon Sep 18, 2006 4:12 pm » Post: #7 » Download Post
Er... take it apart and you'll find out!
Above is best case scenario - the crank may be screwed!! (I can't quite see into the cases from here! Maybe if you park the bike facing the other way I can diagnose it!!!) Rolling Eyes
aikawa
Mon Sep 18, 2006 4:15 pm » Post: #8 » Download Post
Ok Thanks Andy for the help...
sorry for the inconvenience..
93' MC21
Mon Sep 18, 2006 4:23 pm » Post: #9 » Download Post
Laughing
It's not an inconvenience, but until you at least pull the pipes off and have a look up its chuff, you won't have any idea where to start.
If you are really really lucky, maybe it's something really silly like a broken coil or dead plug! There's just not much anyone can do from behind a screen.
It sounds like a seize though, and on a stock bike that's usually down to poor maintenance I'm afraid.
