Play in RC valve cables
sheamuz
Tue Sep 19, 2006 1:32 pm » Post: #1 » Download Post
It says that the rc valve cables need to have 0.5 - 1.0 mm of free play in them. Is this free play along the cable or when you move it side to side. My cables are quite loose when you move them side to side, should they be taut. Rolling Eyes Probly pretty obvious but just thought i'd ask. thanks
Tue Sep 19, 2006 1:39 pm » Post: #2 » Download Post
I thought Andy had a picture somewhere of the cable slack. I can't be bothered to look 'cos there's a bottle of Jack right here that needs demolishing
sheamuz
Tue Sep 19, 2006 1:43 pm » Post: #3 » Download Post
Its Tuesday man!
Tue Sep 19, 2006 1:44 pm » Post: #4 » Download Post
Hang on Mr Matt, I'm comming!
sheamuz
Wed Sep 20, 2006 12:36 am » Post: #5 » Download Post
anybody got a picture or answer. i only just got my bike and dont want to be buying a new servo motor or pgm. thanks
bykpimp
Wed Sep 20, 2006 2:13 am » Post: #6 » Download Post
Free play in the cable itself. Cable not sheath.
mick
Wed Sep 20, 2006 8:29 am » Post: #7 » Download Post
There are adjusters on the barrel ends of the cable, so you should be able to adjust it out.
Take care to make sure they are still aligned properly.
Wed Sep 20, 2006 11:18 am » Post: #8 » Download Post
Think of it as the RC valve pulley needs to have a millimeter play in it before the motor starts to turn.
sheamuz
Thu Sep 21, 2006 12:52 am » Post: #9 » Download Post
thanks very much. i don't think it will matter much now anyway. put a new battery in last night and servo didnt run with the ignition on Sad . will the bike run at all even if the servo isnt working. i dont think there is anything wrong with the pgm cause all the lights are working.
Thu Sep 21, 2006 2:11 am » Post: #10 » Download Post
The bike will run even if the servo is unplugged, but RC valve position will then of course need to set by you (ie fully open).
Check all your connections.
Even if the PGMIII is damaged the lights will still work.
sheamuz
Thu Sep 21, 2006 10:38 am » Post: #11 » Download Post
thank god for that. something simple like checking the connections. i checked them and gave them a clean out with air. BIKE STARTED AFTER BOUT 4 KICKS. Very Happy . rc valves are working. didn't idle real well and was making some pinging noises. for starters i thought it was coming from one of the cylinders on the right side of the bike but when i pulled the clutch in there was a lot of noise like something was loose. i don't think its running at its best, i checked the plugs and there was a lot of excess fuel on them and will be doing a compression test on the engine soon, in the meantime has anyone had this sought of noise from what i think is the clutch
jkolewski
Thu Sep 21, 2006 2:22 pm » Post: #12 » Download Post
does it sound like someone shaking a bag of bolts Shocked You've got a dry clutch. They all make that noise.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Thu Sep 21, 2006 2:24 pm » Post: #13 » Download Post
Laughing
That wil probably be an SE or SP then! "Don't worry mister, they all do that!". It's why we buy them!!
Of course, if it's a 'R', then you have real problems... like a transmission built by NSR.Wayne or something!! Laughing
mick
Thu Sep 21, 2006 9:33 pm » Post: #14 » Download Post
Andy wrote:Laughing
Oh yes, and some of us take the damping rubbers off. Wink
