rebuilding suspension
bushman
Thu Oct 05, 2006 12:57 pm » Post: #1 » Download Post
is it possible to rebuild the shock on an mc21?if so any mods i should consider.i will also refurbish the front end,anything i should consider for this?I have the time now i am awaiting a pgm,so any help would be great.
j911brick
Thu Oct 05, 2006 1:39 pm » Post: #2 » Download Post
What suspension do you have? SP, SE, R? They can all be rebuilt, but the rear shock is pretty hard.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
Wrench.
Thu Oct 05, 2006 2:54 pm » Post: #3 » Download Post
The consumable parts on the SE/SP shock (seals, etc) are all identical to the Honda CBR600 F3, I believe.
If you want to revalve it, you could ask Matt from Tyga for the NSR F3 shock valve/shim setup and duplicate it on your own shock.
Alot of times, you can get away with jest refreshing them with new oil and a fresh charge in the cannister. You will need to fabricate your own service valve or buy an aftermarket end cap for your nitrogen cannister.
If you want to service the shock yourself, you can pick up a high-pressure bicycle shock pump to charge the shock. I picked up a Fox pump for about $20 from Ebay that pumps up to 200psi. Works awesome!!
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
bushman
Thu Oct 05, 2006 4:30 pm » Post: #4 » Download Post
it's an R model,the shock is o.k. a bit soft,but i may replace it with something else olins,or penske.any suggestions?
j911brick
Thu Oct 05, 2006 6:11 pm » Post: #5 » Download Post
Anything you do will be an improvement. About all you can do for the forks is emulators. Your better off to get at least SP forks. Maybe even CBR600 F3 forks will fit, but I'm not sure. SP rear shock would be a step up, but if you can do Ohlins all the better.
james
MC21 Rothmans
RS250
RC31
CRF250X
748R
Porsche (many)
rgvsean
Sat Oct 07, 2006 3:46 pm » Post: #6 » Download Post
I wouldn't put air in a shock. Nitrogen is used as it is affected much less by temperature (changes the pressure) and is dry so won't affect seals and internal parts.
Getting it totally refreshed and sprung should cost about £150 and can be tailored to your weight and riding requirments.
http://www.rgv250.co.uk
http://www.thetuningworks.com
Wrench.
Sat Oct 07, 2006 6:57 pm » Post: #7 » Download Post
Yes, you are correct. Nitrogen is better. But how much?? Let me see; ambient air is at least 75% Nitrogen in the first place. The thermal expansion differential between "pure" (actually about 95%) Nitrogen and dry air is so small it is virtually undetectable. As far as corrosion goes, yes, that is a problem. How much so? Well, I worked on aircraft hydraulic systems for the Air Force for almost 10 years. They used dry air for the last 50 years, and switched to Nitrogen a few years ago because some of their 30-year old aircraft were showing signs of internal corrosion on the landing gear struts (the landing gear struts use air on top the oil as the internal "spring" ranging from 1000-3500psi).
I dont know about you, but I service my suspension about once a year. Never had any problem in streetbikes or dirtbikes using "dry air" instead of nitrogen, and save a ton of money by it. Actually, I would bet good money that my suspension will last longer than most because I change the oil more often. Very Happy
Price-wise, I can service my own shock for about $3, not counting the initial $20 for the pump.
Paul Herr
MY BIKE PICS
rgvsean
Sun Oct 08, 2006 8:56 am » Post: #8 » Download Post
I am also experienced in gaseous and hydraulic aircraft systems. The nitrogen I use is 99.9% pure and dry.
It's actually around 78% in the atmosphere but it's the 21% of oxygen that is the problem and if you live in an area like the UK a lot of moisture.
I personally don't want to put 'air' in my £500 shock absorber and I don't think it's fair to advise others to do this either without explaining the advantages & disadvangtages. The only advantage being short term cost.
I wasn't trying to correct you but just sought to clarify for others that air is not what is normally used.
fenton
1990 Honda NSR250 MC21
Sun Oct 08, 2006 9:23 am » Post: #9 » Download Post
last time i filled a shock i took it on site with me, being a pipe fitter/welder and splicing into 12" gas mains there always plenty of Nitrogen around for purging lines so if you take you shock to your local pipe fitter chances are that you will fill it for free Very Happy
Wrench.
Sun Oct 08, 2006 3:32 pm » Post: #10 » Download Post
Yep! That could be a problem! Sorry guys, but I live in a desert region... Razz
Oh, by the way, doesnt the normal air that gets trapped inside your forks bother you at all?? Shocked
Paul Herr
MY BIKE PICS
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Oct 09, 2006 2:05 am » Post: #11 » Download Post
I now use only nitrogen when rebuilding the shock. I have used normal air before, but that was when I was a boy and didn't know any better. Having said that, it was apart so many times that I don't think corrosion had any chance to set in.
rgvsean
Mon Oct 09, 2006 5:45 am » Post: #12 » Download Post
Yes, that's why I totally fill the forks up to full with oil to prvent this Wink
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Mon Oct 09, 2006 6:37 am » Post: #13 » Download Post
Nice one Sean. That'll stop that pesky corrosion. And no more soggy forks!
Luke F
Mon Oct 09, 2006 8:57 pm » Post: #14 » Download Post
Oil in the forks Matt
I thought they were ment to be full of Cappachino type fluid such as the stuff from my CRF? Shocked
Farting is funny
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Tue Oct 10, 2006 1:32 am » Post: #15 » Download Post
That's right mate.
Or like Ryan's YZ250 that had gravy in one leg and chocolate custard in the other. Yummy
