MC 18 forks
franky
    Send private message View user's profile MSN Messenger Yahoo Messenger
MC 18 forks
Sun Dec 03, 2006 1:40 am » Post: #1 » Download Post
Does anybody out there have the measurements for '89 NSR MC18 forks-from centre of wheel to top of fork leg. I have noticed my forks have a 20mm+ spacer between fork yoke and steering head adjusters! Also my forks stick up through the clamps by 27mm-is this normal or do you think the forks have being changed?
maxim
Sun Dec 03, 2006 11:17 am » Post: #2 » Download Post
I believe the 18-28 share a 710mm fork length from the points you have queried.
franky
MC18 fork length
Sun Dec 03, 2006 7:24 pm » Post: #3 » Download Post
maxim wrote:I believe the 18-28 share a 710mm fork length from the points you have queried.
I have just had a measure and mine are 715mm from centre of wheel to top of fork leg or 745mm from top of fork leg to bottom of fork leg! Does this sound about right?
maxim
Sun Dec 03, 2006 11:21 pm » Post: #4 » Download Post
Yes that's about right.
Sun Dec 03, 2006 11:34 pm » Post: #5 » Download Post
The MC18 top yoke as standard has around a 20mm spacer under it above the head race lock nut but is part of the yoke. What you might find is you have a MC21 top yoke that someone has then made up a spacer for as the '21 yoke doesn't have this spacer as the head stock is taller on the '21 than the '18.
