The oil light should light up when the ignition key is first turned on with the kill switch in the run position. It will then go out after a few seconds. If it doesn't light up then either the bulb has gone or you have a short in the wiring. _________________ If I have to take the carbs off once more...
If you jump the 2 wires (I think its 2) for the oil tank sensor the light should light up with the ignition on. This will test to see if its the sensor or blub/wiring at fault. _________________ If I have to take the carbs off once more...
My MC21 has a PGMII wiring and it seems that the sensor red plug cables do not mutch. i removed the sensor and when i activate the sensor the 15amp fuse was burned then i checkd the diagram with the plug in i got this conlcusion, will fixi the correct order tonigh
