Honda can order NSR head races, I think a full set comes in at around £65 including seals. I knows yours are dead, you could feel they were pushing the bike around the yard lol _________________ If I have to take the carbs off once more...
yep i took it out yesterday and it was knocking every time i hit the brakes i should have done them when i did the front end but the cash dryed up i knew that they have been bad for some time but its gone to far now just to pack them with grease again
fenton wrote:as the parts bloke up here said he cannot get nsr parts not sure why
Pidcocks claim the same "can't get them" (well the one in Derby does), they can't/won't look parts up for any grey import and won't order parts with just a part number provided by a punter. I think possibly as they're that big and organised there is no process in place for ordering a part not "on the system".
Whereas the tiny Honda dealer in Heanor will blindly order any part numbers you like to provide, he just writes them down in his book and orders them the next morning along with all the normal order which is also just written down in the book.
They'll just be generic Honda bits anyway, the same bearings, dust covers etc are used in the RVF400 as well. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I had to order some parts urgently last year and went to Doble's, who I think are the biggest, as in shift the most new bikes, Honda dealer in the UK, and they ordered up the part from the part number with no questions. There should be no reason for them not to get the part...
I'd stick with OEM rather than taper roller Fenton. _________________ NSR300R - Why did i ever have a 250...
Interesting then that they are the same part numbers;
The VFR400 is totally different (see here) and uses the same bearing top and bottom. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Sorry I forgot that the RVF had the spindly top yoke the same as the NSR. The RS and VFR400 share the same top as they both use the much larger steering stem. _________________ If I have to take the carbs off once more...
