Barrel has had light work to both exhaust port and RC valve. The exhaust port has been raised and widened, and the RC valve has been welded and re-ground to match exhaust port.
The cylinder and RC valve are both brand new and have never been used, and will give a nice kick to any NSR150SP.
Cylinder is marked "B"
£200 plus shipping if anyone's interested. Or if you need any more pictures let me know.
_________________ If I have to take the carbs off once more...
An A barrel uses a A piston. B barrel uses a B piston and so on.
B is what is normaly fitted to a stock engine.
However as long as your piston to bore clearance is ok you can mix and match as you choose. _________________ If I have to take the carbs off once more...
I make things go faster not slower. I would think you would be better off getting an NSR125 rather than go to the trouble of trying to get an NSR150 down to 125. _________________ If I have to take the carbs off once more...
Yeh,sorry for treating it like a forum i got confused there for a minute:( Im new to these!.I am interested RC45 ill get back to you on this i just need to get some more funds.
