I HAVE AN MC18 WITH AN 18 INCH STANDARD REAR WHEEL FITTED I HAVE JUST BOUGHT A NEW SHOCK FOR IT BUT IT'S NOT OFF THE SAME MODEL,IT'S OFF AN
NSR250R SP OR SE BIKE THE SELLER SAID IT WOULD FIT AN MC21 GULL ARM.
MY SHOCK IS 290MM IN LENGTH FROM THE CENTER OF THE TOP EYE TO THE CENTER OF THE BOTTOM EYE THE SP/SE SHOCK IS 300MM LONG SO NOW IT DOES'NT FIT MY MC18 IT SEEMS THAT THE LINKAGE NEEDS TO BE CHANGED BUT I DON'T KNOW WICH PART CAN I USE A GULL ARM LINKAGE ALSO WHAT PART IF SO DO I NEED, THE TRIANGLE BRACKET OR THE TIE ROD OR BOTH.
CAN I MAKE IT FIT?[/img]
