anyone useing a 160/60/17 rear tire on a mc28? i have the tyga side by side exhaust and the tire comes very very very close to the pipes. got a great deal on these tires or i would have gone with the 150 size. anyone got any input for me. thanks.
Close to the pipes?! I've got a 165 on the rear of mine and there is plenty of clearance to the exhausts... Have you got a pic you could post? _________________ NSR300R - Why did i ever have a 250...
Tractor engine, tracktor tyres, what ever next? Sure you hav't got a Tri-moto there Maxim? _________________ If I have to take the carbs off once more...
So what does an RS/TZ use eh? Hmm, 120 front, 165 rear... Plus, brand new 106/108 slicks for £40 was a bargain I couldn't miss! _________________ NSR300R - Why did i ever have a 250...
I currently run a 150/60 (stock size) on my MC21R Trackbike, however, when running my slicks 160/63/17 I have to add @ least 2 links to my RK Gold 520 chain, this needs to be done to allow rear wheel clearance from my right side chamber. It will change the geometry(longer wheelbase) and will compromise handling but give better stability in turns. my .02
Just undo the offending pipe, rotate the header sleeve a bit and you can make loads more room.... _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
fontyyy wrote:Just undo the offending pipe, rotate the header sleeve a bit and you can make loads more room....
My bleedin` brand new Tygas` scraped on the track at Llandow on the right hand side. I jiggled the 300 stubs to get clearance from the swinging arm. No problems with tyre clearance. I`m running standard size tyres though.
I'd say...stock tyre size150/60/17 has the best performance.... _________________ 1996 HONDA RS250
1995 MC28 NSR250 SE red/white/green
1994 MC28 NSR250 sp W/ RS250 engine
