as the shaft had pitted where the seal sits, and the plastic drive wheel
has cracks . while waiting for a new one . two stroke oil is leaking from
the oil pump drive hole in the side casing. into where gear oil will be.
are there eny seals at the oil pump i should replace ! . is this ok
have new drive waiting to fit . mc18sp many thanks
