rs250 barrel on nsr
frogger_nude
rs250 barrel on nsr
Fri Aug 24, 2007 2:34 pm » Post: #1 » Download Post
does anybody know what nsr250 model will take a pre 1993 rs250 barrel?
make mine smokey Very Happy
Fri Aug 24, 2007 2:43 pm » Post: #2 » Download Post
Hello Frogger, and welcome!
All the NSR's will take an RS barrel, but it's not as simple as just bolting it on.
You would be better off with a well tuned NSR barrel in most cases.
frogger_nude
Fri Aug 24, 2007 2:47 pm » Post: #3 » Download Post
its for a top secret project Twisted Evil
so a 93 rs barrel will definately fit a mc21 or mc28?
Fri Aug 24, 2007 2:49 pm » Post: #4 » Download Post
It'll bolt on yes.
frogger_nude
Fri Aug 24, 2007 2:50 pm » Post: #5 » Download Post
excellent, thanks very much guys
Fri Aug 24, 2007 2:53 pm » Post: #6 » Download Post
It will bolt on, but it won't work!
frogger_nude
Fri Aug 24, 2007 2:53 pm » Post: #7 » Download Post
ok, so does anyone know the distance between barrel studs on each model nsr?
Fri Aug 24, 2007 2:55 pm » Post: #8 » Download Post
I do. Thanks for asking Very Happy
frogger_nude
Fri Aug 24, 2007 2:56 pm » Post: #9 » Download Post
obviously machining and planning is required to sort it out. the main thing is that the studs line up with the barrel.
Fri Aug 24, 2007 2:57 pm » Post: #10 » Download Post
You want 88~92 RS barrels and heads.
You will also need an HRC NSR crank or special HRC bearings to run the RS pistons.
Best thing you can do is buy an RS motor and tear it down. It will tell you a lot.
Fri Aug 24, 2007 2:59 pm » Post: #11 » Download Post
My NSR/RS motor
frogger_nude
Fri Aug 24, 2007 3:02 pm » Post: #12 » Download Post
what parts with what? nsr bottom end with rs top or vice versa?
Fri Aug 24, 2007 3:05 pm » Post: #13 » Download Post
Thats a F3 set of crank cases with F3 crank, A kit piston and mod'ed RS barrels and heads.
frogger_nude
Fri Aug 24, 2007 3:08 pm » Post: #14 » Download Post
was it much work to get the rs cylinder head to match the crank opening?
Fri Aug 24, 2007 3:08 pm » Post: #15 » Download Post
I'll give you a tip Frogger...
Order an NSR, an NF5, and an NX5/NXA base gasket! That will only cost you £15, then you can compare the stud patterns etc.
It's not perfect, but it is cheap, easy, and quick, and will get you started!! Smile
Can you fill out your location in your profile too please?
