MC18 cylinders and pipes onto a MC16
Canuck13
Thu Sep 27, 2007 11:01 pm » Post: #1 » Download Post
Is there any advantage to changing out the MC16 cylinders and pipes with MC18s? Is there anything else that should be changed, eg carbs, electronics.......
Thu Sep 27, 2007 11:37 pm » Post: #2 » Download Post
I'm sure beakergixer750cc or jeff350lc will be along shortly! Wink
Kieran
Sun Sep 30, 2007 1:41 am » Post: #3 » Download Post
Heeeps of advantage.
I actually had a MC16 bottom end and gearbox in my MC18. The '18 cyls go straight on, '18 heads go straight on '16 cyls too. The electrics will swap straight over, as long as you swap the whole system. And if you get the PGMII electrics, you will have to use the '18 carbs and mounting rubber cos the PGMII has a throttle position sensor attached to the carbs.
You end up with a MC18 engine except for slightly different gear ratios.
Worth the work. Hell, even the '18 heads, carbs and electrics are worth the effort over the '16 stuff...
My 2cents
The Chopster
Canuck13
Sun Sep 30, 2007 1:56 am » Post: #4 » Download Post
thanks for that. I have a MC16 but have a MC18 dry clutch motor which I picked up cheap with a ruined cylinder, but have found a NOS MC18 cylinder cheap so..............time to play Very Happy
jeff350lc
Sun Sep 30, 2007 9:30 am » Post: #5 » Download Post
With a little work you can fit the complete engine. As Kieran says fit the carbs and electrics if you can. MC 18 pipes will fit with a few mods to the can mountings.
Canuck13
Sun Sep 30, 2007 9:38 am » Post: #6 » Download Post
cool...wasnt sure if I could after a number of people indicated the engine mounting were different. I guess if I cnage the electrics, I will also need to change out the tacho/speedo as well.
