Are there any other bikes that a nsr would share a front sprocket with? I know that the fireblade and buell share the brake pads, so I was hoping some one would have some info on the sprockets. Thanks
NS400 shares the same output shaft, but runs a wider chain so the sproket has to be ground down. Any help? _________________ If I have to take the carbs off once more...
Its a very odd out put shaft. The only sproket thats a direct swap that I know of is a 1988-89 RS250 Honda. They later changed it so the post '89 ones wont fit. _________________ If I have to take the carbs off once more...
