Base Gaskets
mhunter1175
Base Gaskets
Thu Feb 07, 2008 11:46 pm » Post: #1 » Download Post
Does anyone know if there is an off the shelf gasket that is the same as the base gaskets for an MC21? The guy I ordered my parts from said they are on back order, but I have heard that some parts are interchangeable with other Hondas?
Mike
Fri Feb 08, 2008 1:27 am » Post: #2 » Download Post
Yes, the MC28 is the same Wink
mhunter1175
Fri Feb 08, 2008 3:20 am » Post: #3 » Download Post
hahaha thanks Matt!
Mike
Fri Feb 08, 2008 3:43 am » Post: #4 » Download Post
And MC18.
Sorry!
SLF-951
Fri Feb 08, 2008 6:04 am » Post: #5 » Download Post
In another post there is a linked page that says CR125 base gaskets are the same... You just need to trim off the part that seals off where the power valve arm is. Doesn't say a yaer, but, not much had been changed on those engines from 1990 on up to at least 99-00(well at least the casting #'s on the Cyl's was the same)
I have both NSR base gaskets and CR125 base gaskets out in the garage. I will check to verify this and maybe post a pic if it does infact work out. I believe I have many of those CR gaskets and you are more than welcome to a set if they are the same.
Steve
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
Fri Feb 08, 2008 10:08 am » Post: #6 » Download Post
NF4 - RS125
NF5 - RS250
Both those gaskets fit.
Fri Feb 08, 2008 2:47 pm » Post: #7 » Download Post
Although, correct me if I am wrong, but don't both the NF4 and NF5 use KV3 (i.e. NSR250) base gaskets for 0.5mm?
Fri Feb 08, 2008 3:38 pm » Post: #8 » Download Post
RS250 .5mm gasket is KV3, RS125 .5mm is an NF4.
howl
Fri Feb 08, 2008 6:14 pm » Post: #9 » Download Post
I had to wait ages for my base gaskets too, for some reason they are getting trickey to get , got the rings , clips & head gaskets within days.
I was impressed today as I picked up a carb seal kit for my MC18 and was on order for only a week. ( please note a carb seal kit is only for ONE carb ! ) Embarassed
It might be a good idea to order a spare set of base gaskets next time you're in the shop.
Fri Feb 08, 2008 6:16 pm » Post: #10 » Download Post
Doesnt everyone keep a full selection of gaskets in stock?
Fri Feb 08, 2008 7:09 pm » Post: #11 » Download Post
Just a word of caution to anyone considering it... DON'T think you can get away with making base gaskets from 0.5mm gasket paper.
The compression of proprietary gasket paper can be significantly different to that of the high quality OEM Honda gaskets and consequently effect compression ratios which could (worse case scenario) lead to increased possibility of detonation.
SLF-951
Fri Feb 08, 2008 10:17 pm » Post: #12 » Download Post
Ok, I didn't have any CR base gaskets left, all my full kits were robbed of them. But, good for us NSR people, I still have a CR cylinder. So, here we are, this is for sure, a 1990 CR125 jug.... And, the NSR gasket fits near perfect.... Except it lacks the part where the power valve arm is. So there you have it.
Photobucket
Photobucket
Did some other research and the CR gasket was the same part # from 90 to 97.
Steve
MC21
04 NSR50R
93 CBR F2
95 VFR750
89 FL400R Pilot
90 FZR 4/600
SLF-951
Fri Feb 08, 2008 10:18 pm » Post: #13 » Download Post
StephenRC45 wrote:Doesnt everyone keep a full selection of gaskets in stock?
I think I have 3 full sets Wink
MC21
04 NSR50R
93 CBR F2
95 VFR750
89 FL400R Pilot
90 FZR 4/600
Sat Feb 09, 2008 1:54 am » Post: #14 » Download Post
Andy wrote:Just a word of caution to anyone considering it... DON'T think you can get away with making base gaskets from 0.5mm gasket paper.
Interesting note by Andy there.
I've often used over the counter gasket paper to make gaskets, but you do always have to take the crush into account. And generally the thicker the paper the greater the crush factor.
mhunter1175
Tue Feb 12, 2008 2:35 am » Post: #15 » Download Post
hehe.... patience is a virtue the gaskets came in today! Thanks Redline Powersports!
Mike
