Can anyone tell me what the official Honda part number is for the RC valve puller tool. Also, does anyone know where I can buy one? Tyga is out of stock.
have you looked into the unofficial tool for pulling the RC Valve shaft? It's called a pile of washers with the hole bigger then the OD of the shaft at it's largest point. Keep adding as you use the nut to tighten (and lift) the shaft out. _________________ Charles Gallant
got a flat piece of metal drilled a hole through the middle slipped it over and popped the nut back on.
then clamped my flat metal in a vice and drifted it out
it was tuff to come out but then it had been in there a very long time.
all newer than a new thing now though with new seals and clips
