Head Gasket O-Rings MC21
Russ
Sat Apr 26, 2008 2:51 pm » Post: #1 » Download Post
Hi
A bit of advice required as I have confused myself.
I have just recieved some top end rebuild kits and have noticed they don't have any o-rings with the head gaskets.
The new gaskets have indents in them the shape of the cut outs for the o-rings.
Unfortunatly I have binned the old o-rings as they were in poor condition.
Another odd thing was that one of the barrels didn't have a head gasket in place only the o-rings.
Are these o-rings required when you use OE gaskets as I cant find a part number for them.
Russ
MC21SP
fenton
1990 Honda NSR250 MC21
Sat Apr 26, 2008 3:17 pm » Post: #2 » Download Post
that's defanatly not a stock mc21 then they only use a gasket for the head not a o ring like a rs250 ect
Russ
Sun Apr 27, 2008 11:32 am » Post: #3 » Download Post
It looks like these barrels have been modded like RS250 barrels with the insert grooves machined in.
Does any body know the spec on the RS250 o-rings, dia, thickness, material etc.
It would make sense that if you are going to do a mod like this, that you would do it so you can use a standard consumable part thats easily available.
So... I have three choices; put the heads back on with just the OE gasket, find a supplier for the O-rings and fit with O-rings only, or finally, O-rings plus the gaskets.
I suppose there is a fourth option, to source some standard barrels; but I think cost and availability will rule this out on the budget I have set on this bike.
Without a bit more research I am not sure what to do for the best at the moment, and I don't even want to think about the consequences of getting this wrong.
Russ
MC21SP
cgallant
2001 Honda RS250
Mon Apr 28, 2008 1:52 am » Post: #4 » Download Post
2001 RS250 O-Rings.
Large One (outer)
85.3x2
Small One (inner)
61x1.9
Charles Gallant
