If you can get a sensor small enough to sit in the downpipe of each expansion chamber without disrupting gas flow, then it could certainly be an interesting and probably useful setup tool.
EGT's have been used a lot (Matt@TYGA has twin ETG's on his 300) to aid 2-stroke setup, but these look a lot more comprehensive. The displayable information is excellent.
Of course, someone would need to provide a safe baseline setting to enable quick setup, and ideally you want a destructive test to see how far (and how accurately) the system can be pushed! Volunteers?! _________________ Andy.
A complany called INOVATE make an after market AFR meter.
We use them to check AFR on cars when bolting on big turbos and upping boost or installing new computers to make sure they are safe to drive to the dyno to be tuned on the rollers
These work the same a std dyno AFR. A sensor that is screwed in a 1" pipe that is clamped into the end of the exh pipe.
Plugged into a lap top you get real time graphs. Can play back and save ect
We usually clamp it in, run the cable into the car, and head to the highway and tune on the run
But on a 2-stoke, yeah, can get a bit gummed up with oil.
