hi,
i need to remove the rear wheel of my mc21 for a few reasons (new disk, sprockets, fixing the ding in it). ive got the back end of the bike up on my car axle stands but after half an hour and about a litre of WD40 i cant seem to undo the axle nut .
i dont want to put to much torque into it incase i wreck something as i have a habit of doing, is there some trick to it? the left side has about a 24 mm nut and the right side has about a 22 mm, is only one side removable? or are the threads reversed for some reason?
the sooner i get this all done, the better, cos then i can get a roadworthy and reg and ride it legally
woohoo it came off! i think the WD40 worked its way in overnight although it still needed so much force that the bike kept lifting off its stands when i turned the wrench
