Clutch Housing Seal
montsta56
Clutch Housing Seal
Sun Nov 23, 2008 4:27 am » Post: #1 » Download Post
Is Anoyone able to tell me the easiest way of replacing the kickstart seal an the clutch housing seal on a dry clutch Engine ??.
i've add a pic of the seals.
many Thanks
Anthony
Sun Nov 23, 2008 3:47 pm » Post: #2 » Download Post
Er... no different to fitting any other seal. Prise the old ones out, and press the new ones in! Confused
Use a socket with the same OD as the seal as a drift for the the kickstart seal to gently tap it back into place (you don't want to directly hit the new seal), and use the old clutch seal on top of the new one for the same reason.
montsta56
Sun Nov 23, 2008 8:28 pm » Post: #3 » Download Post
Great Cheers Andy
