Blue Marble vs other oils??
shawnzo
Thu Feb 10, 2005 5:58 am » Post: #1 » Download Post
Did a search but not much on type of two stroke oil people use. Read article on Blue Marble, is it worth the cost? Any other BESTS out there??
1985 TZR 250
1988 TZR 250 Marlboro Replica
1992 NSR 250 SE
jeff350lc
Thu Feb 10, 2005 9:11 am » Post: #2 » Download Post
i use motal in my road bikes, have done for years. my 350lc never seized again after i started using it. used rock oil in my gas gas 330 trials outfit. it got the living day lights caned out of it. and only ever needed two piston rings Shocked and a lot of clutches Laughing
if your using pre mix, castrol 747 is good. its a castor oil and smells just like castrol R Very Happy
Thu Feb 10, 2005 1:58 pm » Post: #3 » Download Post
I never (ever!) used anything other than fully synthetics - Castrol TTS, Silkolene Pro2, or Rockoil Synthesis 2.
The Castrol smells the nicest, the Rockoil is cheapest... because of a very nice man at Rockoil South West!
If I ran out of oil, I'd never put anything else in until I found a supply of one of my three!
nsr.wayne
Thu Feb 10, 2005 8:44 pm » Post: #4 » Download Post
is silkolene comp 2 plus any good its fully synthectic and smells better than rock oil? Confused
Binka
Thu Feb 10, 2005 11:20 pm » Post: #5 » Download Post
I did a poll on another forum about a year back.
Out of something like 50 responses the most popular was Castrol TTS
Next was Motul and then Silkolene.
I run a heavily tuned Yamaha-ha 350 and it gets fed Rockoil which has yet to fail even though it's making silly power at over 12000 rpm, revving to 13K regulary. A further testament to Rockoil is that it kept the engine turning over when the primary gear pinion failed - this means that the autolube effectively stops working and you only get a minimal feed.
The RG and LC gets TTS coz it smells nice Very Happy as will the AR and RD 125's - when they get finished.... some day, over the rainbow Embarassed
Binka
Thu Feb 10, 2005 11:24 pm » Post: #6 » Download Post
nsr.wayne wrote:is silkolene comp 2 plus any good its fully synthectic and smells better than rock oil? Confused
Yes, it's a very good oil. You shouldn't have any problems with it, the ordinary injector 2 stroke is more than adequate for stock bikes. I fed my MK1 RG250 that stuff for a year and it behaved fine even though it had a life of hard use...
Even Andy can vouch for that.....
