Only got a rough phone camera pic sent to me , could have been triangular for all i could make out! I am a NSR noob though i my defence. I did read something about changing the heads so the plug was more central but couldn't remember what it was. Thanks for the advice as always
hutch wrote:
Only got a rough phone camera pic sent to me...
Don't get me started on the invention of Satan!
MC18 heads are pretty good already... although you can use a rear on the front, just like with the MC21 and MC28, if you wish. _________________ Andy.
I had RS barrels and heads on one of my motors for a while. It was nice having the O rings but I wouldn't have them over a good set of NSR barrels. _________________ If I have to take the carbs off once more...
There are a few things that, on paper, make the RS barrels and heads look way ahead of NSR ones including:
O-ring heads
True centre-mounted spark plugs
RC Valve design and adjustment
But when you can get the same power from NSR components it kind of makes it hard to justify the expense and hassle of fitting the RS parts. The NF5 RC Valve setup is a pain in the ass on an NSR as it needs all the actuation linkages and control cables for example, and the deck heights are wrong too, as the barrels are designed for the shorter single-ring HRC pistons (and usually AVGAS).
Waaaaaay better off modifying the NSR barrels and heads unless you have the time, knowledge, experience, and facilities to make use of the RS parts. Even then, NOTHING so far can reliably beat well modified original HRC spec 90~91 NSR250 barrels! _________________ Andy.
