Ring gap ?
Neal
Ring gap ?
Fri Mar 13, 2009 6:58 pm » Post: #1 » Download Post
Hi guys ,
I have just received my barrel from the platers and was wondering about the ring gap . What is the recomended ring gap for a race bike with wiseco pistons Question
Thanks for any info
Neal
Fri Mar 13, 2009 8:22 pm » Post: #2 » Download Post
Whatever Wiseco recommend!
There's no answer otherwise, as Honda only provide a figure for standard 250 pistons, which may not be suitable for your application.
Neal
Sat Mar 14, 2009 6:43 pm » Post: #3 » Download Post
Thanks , i will measure the piston to bore clearance and check with the specs .
Neal
Sun Mar 15, 2009 4:59 am » Post: #4 » Download Post
Wiseco provide the info I believe. I seem to recall that they recommend the gap as a formula depending on the bore size.
Deon
1990 Honda NSR250 MC21
Sun Mar 15, 2009 5:16 am » Post: #5 » Download Post
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Sun Mar 15, 2009 5:30 am » Post: #6 » Download Post
There ya go.
It's Sunday.....I couldn't be bothered to look!
cgallant
2001 Honda RS250
Sun Mar 15, 2009 11:44 am » Post: #7 » Download Post
Matt@TYGA wrote:There ya go.
Let me guess, youve been at church all day? Laughing
Charles Gallant
Neal
Tue Mar 17, 2009 5:55 pm » Post: #8 » Download Post
Hi ,
I used the calculations and came up with a ring gap of 0.24 mm .
Does this sound normal to you guys ?
On the box it talks about 0.051 piston clearance .
Any comments or thoughts ?
Thanks
Neal
cgallant
2001 Honda RS250
Tue Mar 17, 2009 6:52 pm » Post: #9 » Download Post
manual shows stock ring gap to be Top 0.30-0.45 and the same for bottom. have no clue what that means for a wiseco piston/ring.
Charles Gallant
Wed Mar 18, 2009 1:24 am » Post: #10 » Download Post
0.24mm sounds a little tight to me. I set a 59mm Wiseco piston ring at 0.35mm, and this works for me.
Neal
Wed Mar 18, 2009 10:57 am » Post: #11 » Download Post
Thanks for the info guys . I will do some more research .
Neal
Neal
Sat Mar 21, 2009 8:39 am » Post: #12 » Download Post
The reason i ask is because when i measured my rings they were at 0.4mm after half a season of racing with 62 bhp . Iput fresh rings only and got back up to 68.5 bhp with a ring gap around 0.2 something .
Neal
