How do you test a power valve servo?
geckoracing1
1996 Honda NSR250 MC28
Tue Mar 08, 2005 7:50 pm » Post: #1 » Download Post
Hi all
I cannot get my powervalve servo (PVS) to work. I've built the bike up from a non runner, so I assume the PVS activates the PV and they complete a cycle when you turn on the key? Mine doesn't. Infact they don't work at all, even when the bikes rev'ed beyond 8000.
Is there a way to test the PVS? Any ideas?
Much appreciated
Dan
daniel.williams@punchtaverns.com
Tue Mar 08, 2005 8:25 pm » Post: #2 » Download Post
It's all in the 250 Tuning section.
geckoracing1
Power valve test
Tue Mar 08, 2005 11:08 pm » Post: #3 » Download Post
Thanks Andy, I had read the tuning section on setting the PV and disconnecting the TPS block connector. My problem is that I can't get the powervalve / servo to work at all.
Wanted to know how and what to test.
Dan
snagger
Wed Mar 09, 2005 8:39 pm » Post: #4 » Download Post
Hi Dan,
Is the PGM ok?
Assuming the valves are free, try removing the servo from frame then remove the pulley and seperate the top and bottom of the servo, be careful as theres quite a few plastic gears in there.
Eventually the motor and the potentiometer will be revield, a simple test on the motor and the pot can be made.
Burnt out motor, snapped wire faulty pot etc.
Never had chance to give the exhausts a good airing yet then!! Twisted Evil
Never did get my bike sorted, sold it now Crying or Very sad
All the best,
Regard's Phil
geckoracing1
PV
Thu Mar 10, 2005 8:11 am » Post: #5 » Download Post
Phil
Thanks I'll give that a try. No the exhausts are actually still at the place I mentioned having the dints pulles out - only a 3 months wait so far!
Dan
