hi memebers got some questions bout the nsr 250 i brought it from week ago its nsr 250 mc 16 and iwant to upgrade it to nsr 21 ihave the pgm and to of cdi's any way
ihad a cbr 600 but isold it after ihad accedint any way iwonder is nsr are faster than cbr 600 ?
im still building it cause ibrought it haven missed parts like chains the two cdi's and when idid buy the pgm and the cdi's ifound out it not for mc 16 so ithought to upgrade it but ifound mc 16 have diffrant wire harness so what ican do to upgrade my mc 16 to mc 21?
THANKS Stephen I thought that nsr would be faster than cbr
I've still got more questions what is the difference betweent wet clutch and dry clutch and if it can work with mc 16?
Hello Vatar, and welcome to our first member in Egypt!
I'm afraid your options are rather limited with the MC16, as the crankcase design is slightly different to the other NSR's. While you could fit a dry clutch to it, it's not a simple bolt-one as it is with all the other models.
As StephenRC45 says, you can fit later barrels/heads, carbs, and with a little work, MC18 expansion chambers, and all these will give a performance increase, but it will never quite be as good as an MC18/MC21. You can fit an MC18/MC21 motor into the MC16 frame, but again it's not a straightforward bolt-in job.
Please search the forum as the differences and options have been covered a lot before. _________________ Andy.
I tried to ride my mc 16 with no air filters cause it not finish yet and when I grab the clutch and step on first gear it stops by itself and to start the engine again it have to be on neutral
another thing I want to know
nsr 250 specification says that
mc16 have Maximum Power: 45PS @ 9500 rpm
mc28 have Maximum Power: 40PS @ 9000 rpm
that means mc 16 more powerfull than mc 28?
Firstly please don't use TXT speak (i.e please type "to" not "2") as it's very confusing for some people who don't speak English that well.
Secondly, yes, in stock form an mc16 is no less powerful than any other NSR and more powerful than an mc28.
The 45bhp limit was a Japanese law, it was reduced to 40bhp in 1993 hence the mc28 is 40bhp.
The "problem" is, on the mc18 mc21 and '28 the engine is electronically restricted to 45 (or 40) bhp, on the mc16 45bhp is the power the engine makes.
The mc18 and mc21 are very easy to get 60bhp from with just a couple of wiring modifications. The mc28 is somewhat harder but it can be done without touching the engine.
The mc16 requires the carbs, barrels and heads from another model, mc18, 21 or even 28 though the '28 carbs are a pain to work on.
In theory the top speed of any standard NSR is 113 mph (185kmh) which once again was a Japanese legal limit.
If you get the power to to around 60bhp you could see 125-130mph, maybe slightly higher f you're small enough to tuck in behind the screen properly, most westerners aren't
_________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
irealy need help idont know how to put my problem one of cylinder's idont know if its working well but it gets alot of oil from the exhaust and the motorcycle not runing at all it just to slow imean real to slow
i asked michanic the one who fixing my bike he said well two problems nothing more maybe you need to change the two cylinder's or you need to change the cdi cause its china cdi that work with tok tok
please guys help me to fix this bike and make it runs again cause its olny nsr 250 in egypt and iguess no 1 in here knows how to fix it
