Problems
frankmc21
Problems
Thu Mar 24, 2005 10:55 pm » Post: #1 » Download Post
I have completed about 50/80kms on my 21 after putting it back together and have 2 problems.Both of the port/chamber gaskets are leaking.I have TYGA pipes fitted and I made sure the surfaces were clean when I assembled them.Is this common or is there a trick to getting these to seal?Also the gear selector seal seems to be leaking.Are these easy to change?Your thoughts always appreciated.
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Fri Mar 25, 2005 2:00 am » Post: #2 » Download Post
Make sure the gaskets and manifolds are clean. Degrease everything.
A thin smear of sealant on the gaskets first should keep them quiet, and then a healthy smear on the manifolds before slipping the pipes on.
Leave about one hour before starting to allow the goo to go off.
