Where to get new crank oil seals?
Cyclepath
Mon Nov 02, 2009 4:43 am » Post: #1 » Download Post
I checked Tyga, no luck.
The marketplace here is down.
Where could i get these as i want to spolit my cases but from what i have read i need to make sure these are replaced.
Thanks
Dustin Boyd
www.cyclepathracing.com
Midwest Pirelli Race Support
Hermit
Mon Nov 02, 2009 5:33 am » Post: #2 » Download Post
Tyga do have the left and right crank seals in stock - look in the MC28 Honda parts section. The center seal cannot be bought seperately as a service part, its an integral part of the center main bearing which can only be changed with a crank rebuild. Mixalisen can source new bearings for a crank rebuild if you want to go down that route, otherwise you need to buy a new crank.
If however, you are only interested in the left and right side crank seals then they are readily available from Tyga (for example) and are easy to change when you split the crank cases.
Hermit
Mon Nov 02, 2009 5:36 am » Post: #3 » Download Post
http://tyga-performance.com/site/product_info.php?cPath=72_80_136_535&products_id=406
Cyclepath
Mon Nov 02, 2009 2:03 pm » Post: #4 » Download Post
Ok, so the MC28 fits the MC18. The part number is different than the part numbers defined in the Parts manual.
I did not know this, i just looked in the MC18 area of Tyga.
Thank you
Hermit
Tue Nov 03, 2009 4:37 am » Post: #5 » Download Post
oh, i assumed you had an MC21 or 28. Email the Tyga guys to double check the seals are compatible.
