Smallest battery?
2Smoke
1987 Honda NSR250 MC16
Smallest battery?
Mon May 10, 2010 8:56 pm » Post: #1 » Download Post
After my battery expiring at Llandow, I need to replace it. Now looking at the difference between the ytx4 fitted and a 3xv battery, could I get away with running the latter?
I know the pgm2 is a bit finicky with its voltages, would the smaller battery cope?
nxrsr20
Mon May 10, 2010 10:36 pm » Post: #2 » Download Post
This has been discussed before, so a search will yield results. The 3XV battery has the same AH rating so you're not changing anything.
pbekkerh
Wed May 12, 2010 12:26 am » Post: #3 » Download Post
Do you only drive on tracks or also on the road ?
For track use I have a 1.2Ah battery like this. Its 560g so you save around 1.5 kg
http://cpc.farnell.com/1/1/766-battery-lead-acid-12v-1-2ah-y1-2-12-yuasa.html
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
