They are supposed to be for an MC16 and they are 28mm bore.
They do not have the fittings for the oil pump hoses, nor have they ever been drilled for them.
The throttle bellcrank also has no provision for an oil pump cable and the throttle cables enter from the rear. The fuel hose "tee fitting" exits between the carbs rather than the right side of the right carb.
The carbs on the right are "normal" MC16 carbs for reference.
Anyone have any ideas ?
