Slow Jets and Bent Expansion Chambers (Oh My!)
Skyntara
Wed Nov 17, 2010 4:35 am » Post: #1 » Download Post
Hi Guys,
Another day, another question (or two).
I'm rebuilding my carbs for my new engine. Putting in some Sweet Sweet HRC jets and needles.
However, I find that my two sets of carbs have different size slow jets.
Picture below. Which one is the correct one?
if the picture isn't big enough, let me know and I'll upload a bigger one Smile
Part two of my question...
Seems one of my expansion chambers got a bit munged in my stack. Only just realised how bad when I took the pipes off to drop the old engine out.
Picture below...
As you can see I tried heating then rapidly cooling a couple of the smaller dents. I only have a butane blowtorch so they didn't quite get red hot. Regardless, it didn't work.
I'm seeing the options online as:
1. 80% fill with water - freeze
2. Seal pipes and fill with compressed air, then heat the dents until they pop
3. Drill holes and physically pull or bash the dents out - weld up holes.
Opinions on the best course of action?
Edit: I'll sneak a 3rd question in quickly.....
When setting the needle for the HRC jets is the top or bottom slot number 1? (Which end do you count from?)
Thanks (again)
Clancy
Harryredchow
Wed Nov 17, 2010 7:14 am » Post: #2 » Download Post
What are the part numbers of your two sets of carbs? They should have a number stamped on, like TA22. The reason for the different jets may be because they are different models of carb.
pvan340
Wed Nov 17, 2010 8:19 am » Post: #3 » Download Post
I have heard of (and read about) heating the expansion chambers after filling them with compressed air, but it's really really dangerous. So unless you feel REALLY confidant with getting just enough air pressure and just enough heat, I wouldn't go down that route! Take it to a reputable exhaust shop would be the best answer for me anyway. Good luck!
Skyntara
Carbs
Wed Nov 17, 2010 8:39 am » Post: #4 » Download Post
They're both TA22B carbs.
Seen vids on youtube with the compressed air method. Seems it's only about 30 PSI so not exactly huge.
dunkenb
1989 Honda NSR250 MC18
Wed Nov 17, 2010 9:03 am » Post: #5 » Download Post
think the longer slow jets run slightly richer. sure if i'm wrong some one will correct me! lol
Skyntara
Wed Nov 17, 2010 9:22 am » Post: #6 » Download Post
Are they both mc21 slow jets?
<General Jet Question - Hope it's ok???>
If the long ones are 38s but run rich and the short ones are 42s, which is going to be richer and which is going to be leaner?
Neal
Wed Nov 17, 2010 9:25 am » Post: #7 » Download Post
you plug off your pipe , pump in your air , heat the area of dent gently and most of the dent will push out . The stainless is very thin
Wed Nov 17, 2010 10:50 am » Post: #8 » Download Post
The short #42 is HRC, and unless you're running pre-mix, highly likely far too rich.
A long #38 will be richer than a short #38, but not richer than a #40 or #42.
barryj
Sun Nov 21, 2010 4:53 pm » Post: #9 » Download Post
pvan340 wrote:I have heard of (and read about) heating the expansion chambers after filling them with compressed air, but it's really really dangerous. So unless you feel REALLY confidant with getting just enough air pressure and just enough heat, I wouldn't go down that route! Take it to a reputable exhaust shop would be the best answer for me anyway. Good luck!
Can you explain why you think its dangerous?
Sun Nov 21, 2010 6:53 pm » Post: #10 » Download Post
Because if you get it wrong it will blow your head clean off your shoulders?
Canuck13
Re: Carbs
Sun Nov 21, 2010 9:20 pm » Post: #11 » Download Post
And then you heat it up which makes it higher. . . . Shocked
good old pv/nrt Rolling Eyes
cgallant
2001 Honda RS250
Sun Nov 21, 2010 10:23 pm » Post: #12 » Download Post
I used the "send the pipes to an expert and let them fix it method". Worked great and wasn't all that expensive.
Here are some before/after pics of the dent(s) I had removed. Much larger then what you have.
Charles Gallant
