B piston on B cylinder
RVT2002
Tue Nov 30, 2010 4:03 am » Post: #1 » Download Post
Is it ok to fit a B piston on a B cylinder? I know it should be the No mark piston that should be use on B cylinder. I have spare B pistons and trying to see if fitting it is not a bad idea? Smile
mighty max
Tue Nov 30, 2010 9:37 am » Post: #2 » Download Post
Can anyone enlighten me about A, B & C cylinder?..I thought there only A, B & C piston.
RVT2002
Tue Nov 30, 2010 9:54 am » Post: #3 » Download Post
A cylinder - B piston, B cylinder - No mark and C cylinder - D piston . I'm not sure for mc16 but I know the ns400r and ns250r has A,B,C piston
N
Thu Dec 02, 2010 3:19 am » Post: #4 » Download Post
Measure the clearance and use whatever gives you the correct clearance; 0.039~0.045mm according to the book.
RVT2002
Thu Dec 02, 2010 3:35 am » Post: #5 » Download Post
Thanks matt. Smile Is the B pistons bigger or smaller than a no mark piston?
Thu Dec 02, 2010 3:52 am » Post: #6 » Download Post
Pistons:
B - 53.966~53.969mm
No# - 53.962~53.965mm
C - 53.958~53.961mm
manuryno
Fri May 17, 2019 12:35 pm » Post: #7 » Download Post
Hi everyone!
Bring this topic back to try to find out which in the biggest piston available for my MC 21.
The manual says thereīre three sizes: B - 53.966~53.969mm
C - 53.958~53.961mm
I donīt know if this is right, as itīs the first time Iīve seen this system, usually the A piston is always the smallest.
The other strange thing is that Iīve found these pistons in the parts list: B piston 13102-KV3-830
No# piston 13103-KV3-830
D piston 13104-KV3-830
Does anyone know the reason of this difference and/or the real sizes of the pistons in the parts list? I need to fit the biggest ones as my cylinders are close to the wear limit.
Thanks a lot!!!
Two Stroke Power
Fri May 17, 2019 2:46 pm » Post: #8 » Download Post
If you are replating barrels, send in the pistons and ask for the correct clearance
