carb synchronising
fovu
carb synchronising
Sun Mar 06, 2011 1:09 pm » Post: #1 » Download Post
hi
can anyone tell me how to sync the carbs?i know you adjust it with the small screw inbetween the carbs but can you see the slides move so you can see if your on the right track?
NSR-LOVER
Sun Mar 06, 2011 8:11 pm » Post: #2 » Download Post
if you remove the airbox you will see the slides of the carbs. on each slide there is a sign you can use when opening the throttle the 2 signs must hide together. thats how i do it anyway!
{.bLanK}GoD
Mon Mar 07, 2011 6:45 am » Post: #3 » Download Post
With a Manometer.
fovu
Mon Mar 07, 2011 8:11 am » Post: #4 » Download Post
thanks,that is what i ended up doing,turns out they were ok but found a blocked slow jet on the front cylinder,much better now
