Im having some trouble with the setting the valves with the HRC method. I adjusted them yesterday by feeling the "lip" (best way i can describe it) but according to the diagram i think i set them of the square Bolt?? or was this the RC Valve?
The diagram looks like i should feel the Bolt first then further in the RC Valve. All i can see tho is the Square lipped section (Possibly bolt) that i adjusted or beyond that the exhaust port.
Also i only warmed the bike up, removed the tank - set the servo as per 2500rpm then removed the exhausts etc. Was i meant to do the on /off TPS part first? I figure that part isnt needed as the servo is already set to open the RC Valves.
Either way the bike is running a lot better, thanks for your helping your local village idiot
