Have you tried WD40 and rotated the bobbins to see if it's just stuck? A bolt through the bobbins will allow you to rotate them. I thought my disks were warped, but after doing this they were fine. Note: Should be obvious but don't put the WD40 on the main part of the disk, and you'll need to clean the excess off before reuse.
Thanks for that paul, and i wouldnt mind trying it pls.
I did check the bobbins and they were a bit stiff and freed off, but still i can feel more of a pulse than i am happy with.
are they handed ?
Cheers chaps
