mc16 engine
adamp76
mc16 engine
Thu Aug 18, 2011 6:53 pm » Post: #1 » Download Post
hi just wondeing what the difference to a mc16 engine to a mc18 engine as all
i can find is a compele mc16 engine to fix into a mc18 frame , would it be a straight fix in no messing ?
cheer adam
Neal
Thu Aug 18, 2011 8:47 pm » Post: #2 » Download Post
It can work , you may need to modify the rear engine mount on the 16 cases as they are wider and need to be cut down .
Canuck13
Sat Aug 20, 2011 3:31 am » Post: #3 » Download Post
Also fwiw MC16 is rigid mounted. . .
kaloo1812
Mon Oct 10, 2011 12:41 pm » Post: #4 » Download Post
Neal
neal where in durban you at?
Mon Oct 10, 2011 2:08 pm » Post: #5 » Download Post
Adam, save yourself the hassle, and find an MC18/21/28 bottom-end... and also save a set of 24 year old crank cases from a butchering!
The MC16 cases aren't very good internally anyway, and need a lot of work to get them flowing as well as the later models, although it can be done easily enough. Also, the barrels have much smaller exhaust ports and the motor as a whole will never give you much over 45hp in standard form, if it's in good condition and well optimised. It won't do the MC18 chassis any justice.
What exactly are you struggling with for your MC18? Is it a Mk1 or a Mk2?
