300 modifications .
Page 4 of 4  Goto page Previous  1, 2, 3, 4 Download Topic
Neal
Thu Dec 22, 2011 4:19 pm » Post: #46 » Download Post
Place your barrel onto the case and look at the bottom pieces that fit into the casings , use a small ruler for eg and you will see if everything lines up and is clear .
Open up the oil holes on your piston too to help with cooling the bridge .
Matt@TYGA
Supporter - Vendor
Supporter - Vendor
Fri Dec 23, 2011 5:19 am » Post: #47 » Download Post
I too just get stuck in there with an air grinder. But don't use grinding stones on aluminum as they'll get clogged double quick.
I have some big roughing cutters that can really chomp the material out, and then progressively less savage.
NSR300 Discussion
