Sorry to repeat questions out of my build thread, but I figured they might get lost amongst the pretty pictures.
So my questions are:
Will it matter not having the anti judder springs (these are the shaped metal springs in the clutch) in a race bike? (a common mod to the 400's was to take these out and replace them with a full size fibre plate)
Does anone have a spare single full sized fibre clutch plate (*assuming it doesn't matter, and based on my 400's experience it shouldn't)?
Is there something special i need to do in the absence of a crank balance mark to line up with the clutch basket? I did my utmost to guestimate position based on the previous crank mark....but still....
Anything special I should keep in mind when putting together the kickstarter? I made sure to get the pawl behind it's little catcher, is that all?
how worn a clutch plate can you handle? I have one you can grab, if you ask nicely you can even grab one with nie discolouration from the previous numpty that overheated it
I am not sure of the clutch/crank line up mark that you talk about. The inner and outer baskets do have to line up, there is a dowel pin that slots into a slot.
If this is your track/race bike, why run a kickstarter when you are going to great lengths like running premix? The pawl is the kick start spring? Don't forget that too.
