Power Valve Bush Removal...Helppppppp
Hobbit210
Tue Feb 07, 2012 9:55 am » Post: #1 » Download Post
I'm just about to send my barrels off for re-plating but have just had a thought...The bush that supports the inner end of the power valve, it it important to remove them before the plating process and if so ...How?
Thanks in advance.
Mike
Alzazorq
Tue Feb 07, 2012 10:45 am » Post: #2 » Download Post
I always remove it as sometimes we had the barrels returned without the bush. They tend to forget about it and once in the acid bath its gone...
You need to find a shaft that will fit into the bush tightly, eg. an old drill bit, or new one...
Then you apply grease to "pack" the bush, then tap the shaft with a hammer to hydraulically lift the bush out of the barrel. (The shaft forces the grease underneath the bush to push it out.)
You might have to pack the bush more than once with grease.
Mario
Hobbit210
Tue Feb 07, 2012 11:02 am » Post: #3 » Download Post
Many, many thanks Mario for your detailed description.
Mike
Hobbit210
Tue Feb 07, 2012 1:46 pm » Post: #4 » Download Post
Well I've tried and tried and tried but the little buggers wont budge. I'm using a 5.6mm drill which is a decent fit but, to be honest, I am worried that I might do some damage if i hit it too hard.
Mike
Alzazorq
Tue Feb 07, 2012 2:57 pm » Post: #5 » Download Post
Sometimes you will need to give it a couple of proper smacks...There's not much you can break there, maybe the bit or your fingy...Smile
Neal
Tue Feb 07, 2012 8:26 pm » Post: #6 » Download Post
I would hope that the replaters can get it out , and yes you can damage something . I had a barrel leak water from that same bush area ,
they cut it open from the outside , welded it and returned it looking untouched in working order .
Hobbit210
Tue Feb 07, 2012 8:50 pm » Post: #7 » Download Post
Thanks for the replies again.
I've spoken to Langcourts today and they have assured me that they will look into what is the best thing to do about the bushes when they get my barrels. They are quite used to this sort of thing apparently.
Mike
pbekkerh
Wed Feb 08, 2012 3:21 pm » Post: #8 » Download Post
If its disappeared, is it available as a part ?
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Wed Feb 08, 2012 5:59 pm » Post: #9 » Download Post
Langcourts have replated 3 barrels for me over the years and I've never removed that bush...
Hobbit210
Thu Feb 09, 2012 10:30 am » Post: #10 » Download Post
Well they have my barrels now. Can't wait to get them back and start rebuilding Noodle.
Neal
Thu Feb 09, 2012 4:19 pm » Post: #11 » Download Post
What mark pistons are you using ? Did you send them with the barrels ?
Hobbit210
Thu Feb 09, 2012 7:57 pm » Post: #12 » Download Post
My barrels are marked B, therefore no marking on the pistons.
Langcourts told me that they don't need my pistons, is this not true then?
Mike
