Not many pictures of NSR500 or 500V engine parts on the internet so here are some from my rebuild. I'll add more as I dig bits out.
2001 spec engine with revised crankcases, uprated gear box, clutch and clutch cover as well as nitrided output shaft collar. Det rings in both head and barrel. Magnesium water pump, clutch cover and exhaust manifolds.
Tungsten crank with heavy metal inserts. Ceramic centre bearing.
_________________ If I have to take the carbs off once more...
Heads set up up for leaded and unleaded. Some have det rings. 3 types of heads were available, NX6A, B and C. These also different in volume and squish.
Looks stunning but where the hell do you start when working out how to build it up to run on BP Ultimate _________________ MC21 300
Aprilia RS250 track bike
Yeah I know! It's going to cost about £400 a day in fuel to do trackdays. Still cheaper than cranks and cylinders though. You can buy it in 25L drums though as well as 50L. _________________ If I have to take the carbs off once more...
StephenRC45 wrote:Yeah I know! It's going to cost about £400 a day in fuel to do trackdays.
Only if you do the whole day and if you can be as heavy on the throttle as a pro GP rider! _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I'm going on it (with a 26 litre fuel tank) being able to do a 30 lap GP at Donington in the hands of someone very quick. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
