Hello to everybody in the world of NSR's.
I have a PGM II from an MC18 and i want to know if i can use it in the future.
Is anyone know if the PGM I and PGM II can work to MC21(PGM III) wiring loom with no extra parts to change?
Can it works with only the correct wiring connects to the PGM area?
A more straight forward approach,
would be the correct wiring loom and flywheel to the corresponding PGM unit that you intent to use. _________________ 2t-racelab.com
Hi
Then they have difference in spark time from the flywheel?
I am interest to learn if it is necessary to use the wiring loom because it is enouch job to fit it compare to the flywheel change.
If it is only the flywheel diferent it will be so nice because i own also and an MC18 sp bike witch it is not in good condition to ride it and i can take the parts of it to use the PGM II if it is necessary for a future damaged PGM or testing problems on my MC28.
But if it is inevitable to use it with wiring loom i will not going to do all of this job ,to take off the wiring loom from the MC18 and fit it to the MC28 i prefer to buy and have a spare PMGIII:D
