Hello folks, I bought an SE shock for Noodle and will be fitting it very soon once the motor is complete. One problem is that I don't have the mounting hardware for the shock reservoir.
I don't have an SE/SP that I can crib from.
Any suggestions please.
I've got mine held to the subframe with a large stainless hose clamp, i'll post a pic tommorow. I have the mounting hardware for it somewhere if your intrested. _________________ Cheers,
Dave.
You could try a piece of ally L angle , it is easy to work with and you can mount it to the rhs frame spare . Then drill some holes in it to mount the reservoir .
I'd just order the correct bracket from Honda. They fit all the frames R, SE and SP and will allow you to place the res' properly. _________________ If I have to take the carbs off once more...
Mike, the bracket you want, is part no; 52411-kv3-840, £17.60p, special order from David silver. Sometimes special order bits arrive in about a week sometimes a bit longer. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Thanks for the part number Les, I'll order one today. Bit of a way off finishing yet. Just fitting the dry clutch assembly. Sadly it's not in as good nick as the current wet clutch assembly.
I'm using my YPVS at the moment in this good weather. I think it's standard but 'boy' does it go well...Sadly...it doesn't Stop the same
