Paddock stand for mc28
cookiesol
Sun Apr 01, 2012 10:19 am » Post: #1 » Download Post
dear all
any advise on where to get a paddock stand (rear wheel) for a mc28 at a decent price?
miss having 1. makes life so much easier.
otherwise, have seen some of the rides here with bobbins (is that what its called?) on the swing arms so they can use normal stands.
any idea where i can get a set? so i can make use of the existing padlock stand i have
cheers!
Admin edit: Subject line corrected to avoid confusion.
cookiesol
Sun Apr 01, 2012 10:21 am » Post: #2 » Download Post
heres an example. pic was stolen from Jamie's =X
Bully
1994 Honda NSR250MC28SE
Sun Apr 01, 2012 10:44 am » Post: #3 » Download Post
I must say that I wouldn't knowing this too, got to drop the front wheel off mine to sand the fork legs down and don't have any stands at all!! Ideas?
Dana
Sun Apr 01, 2012 11:00 am » Post: #4 » Download Post
Not sure how one would go about using a spool stand for an MC28. I bought a Pit Bull for around $150 if i recall correctly. Was another US $20 for the pin.
For a temporary fix, you could use some tie downs and rafters in a garage to lift up the rear end.
Dana
Sun Apr 01, 2012 11:22 am » Post: #5 » Download Post
Too many conflicting questions here, ones asking about a rear stand for a 28 and showing a picture of a 21, when they both use completly different stands, another ones asking about a front stand, which one do you answer?, or somebody dont know the difference between a 28 or a 21 swingarm. Confusing!!!
cookiesol
Sun Apr 01, 2012 11:42 am » Post: #6 » Download Post
hahahahhahaa
option 1: any ideas on where to get a padlock stand for mc28 (rear wheel)
option 2: able to up bobbins on a 28 like the 21 in the picture? tho i doubt not.
nxrsr20
Sun Apr 01, 2012 8:01 pm » Post: #7 » Download Post
ummm just to avoid further confusion too, it's "paddock" not "padlock" Smile
I can't see where you would mount a bobbin besides on the hub, so you'll need a single sided stand, that is the easiest way out.
With a single sided stand I can't see a reason why any of the conventional front stands would not work, before you test it, make sure a friend is handy..... just in case Smile
cookiesol
Mon Apr 02, 2012 10:38 am » Post: #8 » Download Post
thanks all.
will look ard for a single sided stand then.
cheers!
