RVF400 Front end
Tyga Rear Sets
WP Steering Damper
M-Max de-restrict box
Jha Pipes
HRC rear brake reservoir
Braided brake lines front and rear
Brand new bottom and top end. Kevin Murracy MCE racing did all the bottom end work and the previous owner did the top end. It only has two heat cycles on it.
The following stuff is what is new and zero miles:
Crank bearings, all seals, gaskets, clutch steels and fibers.
New pistons, rings, bearings, reeds all gaskets etc etc.
Carbs haven just been gone through and cleaned.
New oem throttle cables
oem clutch cable
new Daytona brake pads on front, EBC on rear.
Chain and Sprockets (maybe 100 miles)
Coils, plug wires and spark plugs
New hand grips
Tyga Carbon Silencers (for either set of pipes)
All fluids, brakes, trans, injector pump
All bearings and seals pulled cleaned and lubed with redline synthetic grease.
Every nut and bolt and little odd and end was cleaned, de-greased, ultrasonically cleaned or painted etc. All the hardware was cleaned up on a wheel or painted or replaced.
Small plastic parts were cleaned, rubber re-juvenator was used on small rubber bits that needed it etc etc.
So basically the bike is near 100% new, the engine is zero miles fresh, front forks just freshened up with new Motul fluid and seals. I just ordered a new Ohlins rear shock for it
The bodywork is all new, still in OEM packaging. The guy bought what he thinks is probably the last set out of the UK about 7 years ago complete with tank...extremely rare.
Unfortunately I haven't been able to start it yet as it still needs a radiator which he will bring to me next week and help me with getting her fired up.
The bike also came with the following spare parts:
extra good PGM3
Two complete top ends
Lots of clutch bits, coils, plug wires, plugs
base gaskets, head gaskets lots of new little odds and ends still in oem packaging
Stock pipes and passenger pegs, extra bits and pieces.
I also purchased a ton of parts for the bike already which are:
Tyga RSW street front and side fairings
MC28 welded rear seat cowling
MC28 tank (thanks Leigh!)
Misc carbon pieces
New black and red extendable levers
New Pirelli Supercorsa's in 110/70 and 150/60
Tyga airbox and new main jets in various sizes for when I dyno tune her.
I have a spare rear head and just purchased some new shorty plugs and caps to run when I do the HRC head conversion.
I really like the Cabin Racing theme, and plan on painting the new RSW bodywork and MC28 tank to match. I also ordered up a track set of original look plastics but had them ad some racing decals below the Honda decal on the fairings. I just don't want to use the stock fairings and tank and plan on keeping them stored.
Needless to say, I'm very exited and can't wait to get her up and running as I have a track day event on January 12th.
Happy Holidays everybody!! I know mine will be
Here are a couple pictures of the bike and the OEM fairings as well as a little mock up I did with the MC28 welded rear seat cowling and MC28 tank (thanks Leigh!). The MC28 rear seat cowling does not really fit right, the rear HRC brake reservoir seems to be in the way of where a custom mounting bracket needs to go. FOR THOSE OF YOU WHO HAVE PUT AN MC28 REAR SEAT COWLING ON AN MC21, CAN YOU HELP WITH WHAT I NEED TO DO TO GET IT TO FIT RIGHT??
Here is my old MC28 that I ended up selling 45 minutes before purchasing the MC21.
