If you do not have the correct card for your PGM-IV, it may be hard to buy a new one in Thailand. You can try TYGA Performance (based in Sattahip) or Red Baron in BKK.
Maybe it is easier to fit a PGM-III and MC21 wiring harness instead. You may be able to buy it second hand from Red Baron. _________________ Andy.
I mean remove the PGM-IV and MC28 harness, and replace it with a PGM-III and MC21 harness.
It's not a big job, but you will have to fit the PGM-III under the rear seat, lengthen the wires from the stator (generator) to the main harness, and probably fit some MC21 instruments. (MC28 = digital display, MC21 = mechanical.)
As an additional bonus: A standard MC28 only produces 40hp, but if you fit a PGM-III/harness and do the wire-splice you will get an instant power gain:
If everything is standard, and you fit a PGM-III/harness (with wire-splice), you will probably go from 40hp to about 47hp†.
If you have already removed the restrictions in the standard exhaust downpipes, then you will probably go from 40hp to about 52hp†.
If you already have race exhausts, you will go from 40hp to about 60hp†.
Not only will a PGM-III/harness be cheaper and easier to find than a new PGM-IV card, but you will also get "free" power on top!
Please note that you must check your jetting‡, and should modify the airbox as well as the PGM-III harness to get the best power. There are lots of posts about airbox modification on the forum.
† Approximate rwhp figures.
‡ Please do not discuss specific jetting in the public areas. There is a dedicated Members area for jetting discussion. _________________ Andy.
